How to modify skin settings for entire body
Hello, I am working in DAZ 4.10 Pro.  I load a G3M or G3F and go to Surfaces.  I see the Default template and Template 1,2,3, etc.
If I modify the Default template with skin settings, will thsoe changes apply to eyes, nails?
If I should not change the Default template, is there a way to select all the skin templates (face, torso, arms, legs) and apply the skin modifications simultaneously to all the skin templates?
Thanks,
Nathan
    edited March 2018
    @RA " I load a G3M or G3F and go to Surfaces.  I see the Default template and Template 1,2,3, etc"
    I'm not sure what you're looking at. There is no "Template" anything label in the Surfaces Tab.
    Attached is a shot of what you should see when you select G3F and then click the Surfaces tab. If you then click "Skin", you can click the Surface flyout to see what is selected. This is likely what you want. Clicking Skin-Lips-Nails instead adds lips/nail to the selection.
    657 x 720 - 82K
    Post edited by fastbike1 on
  • RARA Posts: 78
    @fastbike1
    @fastbike1 Thank you
  • Alowe49Alowe49 Posts: 42
    Think of the templates as shortcuts to let you to select all of an area at once rather than selecting each through the surface tab.
