Attention Patience55
Faeryl WomynFaeryl Womyn Posts: 3,774
edited February 2018 in Daz Studio Discussion
I had a question regarding morphs when I was reading your tutorials. If I want to make a character using say G2F and that character was small, would I start with the full figure or would it be best to start with the girl base shape before using the bridge to bring to Hexagon, since the character would be closer to that size then an adult.
I'm asking due to the problem of adjusting the rig to match the end result of the character.
  • Moved to Daz studio Discussion sicne it is a question, not an offer of a freebie.
    You should not have any caling applied to the figure before sending it over for morph creation, whether you use other shapes and reverse them out of the morph or whather you work on the base shape will deoend on what you are trying to do - if you are wanting to sculpt additional details on top of a dial-spun shape then you pretty much have to work on the shape, not the base.
  • Faeryl WomynFaeryl Womyn Posts: 3,774
    Ok got it, thanks
