How do I make a smile, frown or open mouth?
Not sure where the option are for opening mouth and stuff like that. Appreciate any help
  • Which figure?
  • dpdiydpdiy Posts: 24
    Which? Why is it not a general answer for all figures?
    Okay, well let's start with a Genesis 2 male or female.
    Where do I navigate to, I see shaping, posing, and parameters for everything relating to the movement of a character EXCEPT opening and closing a mouth.
    I also see adjusting lips and muscles relating to the mouth, but no smiling or frowning.
    Thanks
  • WandWWandW Posts: 2,905
    edited February 2018
    Select either the Genesis 2 or its head, and they willl be in Parameters under Pose controls>Head>Mouth to open the mouth, and Pose controls>Head>Expressions for expressions...
    Edit; Genesis 3 and 8 are set up the same way; I don't recall about Genesis 1, but I belive it is the same as well; I can't check right now as I have a render going...
    Post edited by WandW on
  • LeanaLeana Posts: 13,478
    Because they're not all the same. G3 and G8 have facial bones which can be used in combination with morphs for expressions, but for previous figures you had to rely on morphs only.
    I see, thank you both for your comment. I appreciate it.
