Exponential increase in render time? (Animation)
So, I am trying to learn how to do animations and stuff, using the basic frame-by-frame method (though I wish I knew the methods that look smoother) and doing quick little one second things and seeing how they look in proper motion. Well, I did a 36 frame animation, and starting out the renders were pretty solid at 5 minutes a frame, but now that I'm in the late 20s, it's getting to about 3 frames an hour. Having the program open on screen and nothing running in the background.
What I have is a GTX 1080 TI, 24gb of 2133ghz ram, and a 4.2ghz processor. Basically a meaty gaming rig. I'm basically rendering a 4:3 screen shape, so almost 1080p vertically but square shape when it comes horizontally. The only thing changing from frame 1 to frame 28 is the pose of the character, nothing additional is showing up on screen, or changing lights or anything. So, is this normal? And is there maybe a way to improve, or make more consistent, the render time for animations?
  • Try changing to Iray preview mode before you render. There is something really weird about Iray reloading scenes for repeated renders that causes this sometimes.
  • wolf359wolf359 Posts: 3,955
    edited February 2018
    And is there maybe a way to improve, or make more consistent, the render time for animations?"
    You have not mentioned what the character is wearing.
    Alot of Daz content  has ridiculously high 4k textures
    that are not suitable or even needed for characters in motion.
    The Fact is that DAZ studio's IRay is not a good choice for
    rendering animations as it lacks the optimization options
    of  other PBR engines Like Vray or cycles.
    As you are new to animation I recommend you start with simple
    open GL  test renders to develop your skills before attempting
    Full  resolution Iray or even 3DL renders.
    Post edited by wolf359 on
    These don't slow down animation.
    When your graphic card reaches its Max. What happens to your render times on CPU??
    Surely they still put a strain on things though (e.g. memory management).
    One other thing to look at is how many polygons are in play.  Especially in objects far away from the camera.  This is one area where I like Cinema 4D's LOD (Level Of Detail) feature which can use lower-poly models based upon camera distance.
    Ultimately you really only have two choices to reduce animation time outside of lower frame rate or frame size.  First, cheat as much as possible (flatten layers, reduce polygon count, optimize models, etc.).  Second is to throw hardware at it (to include purchasing time on render farms).
  • agent unawaresagent unawares Posts: 3,513
    They don't slow animation frame to frame like the OP is seeing, because you have to already load them all into memory to render the first frame. It doesn't take more memory on the thirtieth.
    Post edited by agent unawares on
    Theoreticly if indeed Iray Loaded all of the textures onto his card
    then his render time per frame should not deviate far from the first frame.
    According to Kendal sears Iray does not care about Hi res meshes so that
    is not the issue it seems
    If somehow it is dumping the task onto the CPU( via some system error)that would cause a dramatic  drop in performance.
    But we are all  just guessing  in the dark
    as the OP has not described his scene contents.
  • FYI: Decimator for DAZ Studio is on sale right now.  Just picked up it.  Perhaps that can aid in reducing the OP's animation times; I know it will now allow me to do some animation projects now.
    Why would an animation dump the same exact geometry and texture content to CPU if it didn't on the first frame?
    EDIT: @AliPop, does your log file say you are dropping to CPU, or is it using the GPU throughout?
