Transfer Utility doesn't detect figures
When I use Transfer Utility to transfer rigging from figure to an object it detects object as a target or source and I can select it but in the source there is no figure which I could select.
I tried with Michael 4 and Victoria 4 and they don't show up in the "scene item" tab. In previous versions of Daz3D it worked.
I tried to install 4.5 version again but it doesn't work in this version too. I reinstalled Daz3D 4.10 but it doesn't fix it. Help me please.
The Transfer Untility does not work for legacy rigging, as used by Michael 4 and Victoria 4. For those you have to import the figure into the Figure Setup pane (using the pane's file menu), import the geometry (right-click in the groups panbel), and drag the new geometry onto the geometry entry in the Relationships panel to replace the existing mesh, then remove unwanted bones, chnage the figure name, and Create.
