Floor surface disappearing when using Floor and Wall
wsgentrywsgentry Posts: 573
edited February 2018 in New Users
I'm using the floor and wall from Render Studio.  It worked great for a bit, but I've noticed the floor surface I've applied (Tile 10) disappears occasionally from renders leaving nothing but a transparent floor.  Has anyone else experienced this and if so what was your workaround?
Edit:  It works with shaders provided with the package, but they're not really what I'm after.
Thanks in advance,
Scott
Post edited by wsgentry on
  • IllidanstormIllidanstorm Posts: 655
    Check if Draw Ground is on in the render settings and disable it. Or choose Scene only.
    Post edited by Illidanstorm on
  • wsgentrywsgentry Posts: 573
    Thank you!  Draw ground seems to have no effect and Scene only is always on.
    Scott
