Measure Metrics foot size
Hurdy3DHurdy3D Posts: 1,109
Hey, I want the foot size of a Gensis 3 chracter in cm.
I created a new measure for the left foot. I selected the left foot and created it via Create -> New Mesaure Metric.
Than I run the Figure Metrics script and attached my left foot test to left foot length morph.
Bascially it is working, I get a measure and if I change it, the size of the foot is changing too. But I don't get the size in cm. Currently its something like ~0.09.
How can I convert this to cm.
I think it would be a good idea to add the foot size in a future Measure Metrics update ;)
544 x 540 - 59K
1346 x 92 - 20K
1180 x 506 - 46K
Post edited by Hurdy3D on
  • The Measure property displayed in the Parameters pane always displays in Daz Studio native units (cm). The Measure Metrics pane (and the Figure Metrics script) allows you to change the unit of measure displayed within itself.
  • Hurdy3DHurdy3D Posts: 1,109
    I found the solution by myself.
    Here a small tutrial what to do (with a Genesis Female 3)
    1.
    Select the left foot
    2.
    Create a new Measure Metric (Create -> New Measure Metric)
    Type: Tape Measure
    Options: Parent to Selected Item
    Check also the option to create a Persistent Point At Target
    You should now get something like this
    Set the Foot Left Target to:
    X Translate: 13.62
    Y Translate: 0
    Z Translate: 14.03
    Foot Left to
    X Translate: 10.70
    Y Translate: 0
    Z Translate: -9.49
    The Result should look like this
    If you use an other figure then Genesis 3 Female you may have to adjust the values.
    3.
    Move Foot Left Target to Left Big Toe_2. This is nesseracy that the lengths of the Measure will be adjusted when the size of the Foot changes.
    In the Measure Metric Tab you should see something like this:
    4.
    Open the Figure Metric (not Measure Metric!) window (Figure Metric comes with Measure Metric)
    Go to the configuration Tab and select  as Node Genesis 3 Female. I use CTRLFootLength (Foot Length), but you use also PBMFootLengthL (Foot Length Left) if you want measure and change both foots seperatly. I'm not sure if this morphs a part of DAZ or if they are from an Morph Addon.
    5.
    Now you can change the size of the feets in the Measurements tab of Figure Metric.
    482 x 440 - 36K
    574 x 566 - 59K
    682 x 426 - 33K
    1170 x 704 - 90K
    954 x 458 - 66K
    2180 x 482 - 137K
    752 x 170 - 18K
    1168 x 210 - 24K
    1905 x 441 - 91K
    1978 x 778 - 101K
    1268 x 606 - 58K
