V4 morph magnet
Amazon12
A few days ago, I installed the Victorica 4 morph magnets, and EVERYTHING in my poser file was wiped!
Amazon12
How did you install, and which OS? Installing content with the Daz tools (Connect or DIM) won't remove existing content.
I used DIM with Windows 10.
OK. Are the content directory settings in both DIM and DS unchanged, as far as you can see? Have you tried using an OS search fro files ending .duf to see if a folder was somehow moved or renamed?
Found them! For some strange reason, everything in the poser folder was moved to the Daz material folder.
Good, I'm glad they turned up.
