Animating a Node's Parent
For example, is there any way to set a given node's parent to nodeA at frame 0, and switch it to nodeB at frame 1 (and record keyframes for the change)?
Thanks in advance if anybody has any info!
- Greg
  • No, that's a feature that has only recently appeared even in some high-end applications and DS won't do it at all. You either do two sequences, or you might be able to work with two props and switch their visibility.
  • algovincianalgovincian Posts: 2,696
    Thanks for taking the time to answer (and so quickly), Richard. Sometimes, I have trouble finding things that are right under my nose, so I figured I'd ask after my search came up empty. Anyway, much appreciated.
    - Greg
