Marvelous designer Clothes messed up when fit
Hi everyone, i have designed a character in Daz, made a cloak dress in Marvelous Designer and imported it to Daz. But when i rig the dress with Transfer Utility in daz with these settings shown in attached picture, everything messed up (shown in second picture attached). If i uncheck Fit To Source FIgure, dress is fine but also not rigged with character. Please help what should i do to fit the cloth as it is on this character.
1534 x 849 - 187K
1085 x 902 - 117K
  • You could try setting Source Shape to the shape used, or to Current, and then checking Reverse Source Shape from Target. You could also simply import the OBJ, applying a dForce modifier (Dynamic Surface) and let it drape without rigging (you'd want to use an animated drape, starting with with the unposed character in frame 0 and applying the final pose in frame 30 or so).
  • AmaranthAmaranth Posts: 441
    I always make my clothing for the base figure (G3 in your case), run transfer utility and rig the clothing then dial in the morph you like and fix the clothing if needed.
  • Thank you so much for your help, IF POSSIBLE, can you please explain a little about "dial in the morph you like and fix the clothing if needed" or if there is a video tutorial for these solutions ? i am new to daz :(
