Problem with dForce Long Coat Outfit Textures?-(Answered)
frankrblowfrankrblow Posts: 2,052
edited February 2018 in The Commons
Anyone else having problems with https://www.daz3d.com/dforce-long-coat-outfit-textures when trying to apply a different texture to the Long Coat?
The pants, shirt and shoe textures work fine for me, but not for the coat. I have submitted a bug report, as it looks to me to be an error in the product.
Here is the relevant part of the error log text (highlite applied by me):
... 2018-02-24 05:46:55.682 *** Scene Cleared ***
2018-02-24 05:46:55.866 WARNING: fileinput\dzassetdaz.cpp(4667): Could not find node parent.
2018-02-24 05:46:55.997 WARNING: fileinput\dzassetdaz.cpp(1766): Failed to follow node.
2018-02-24 05:46:55.997 File loaded in 0 min 0.3 sec.
2018-02-24 05:46:55.997 Loaded file: Long Coat Outfit - Coat.duf
2018-02-24 05:46:56.278 Loaded image long_coat_Coat_BaseColor.jpg
2018-02-24 05:46:58.108 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2018-02-24 05:46:59.865 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.904 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.934 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.945 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.956 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.957 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.969 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.971 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.980 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.981 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:46:59.987 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2018-02-24 05:47:03.623 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2018-02-24 05:47:03.623 Error reading file, see log for more details.
2018-02-24 05:51:04.674 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
Post edited by frankrblow on
  • Are you using the coat on Genesis 8 Male? That looks like a Hierarchical Materials preset, which will look for the figure the item was parented when it was saved.
    No, I had just the outfit loaded. Now I added Edward and it works. For G8M and G8F, but not for G3M. And that's a little troubling. I can see that this is because it's for dForce, but I had hoped to use the coat on other figures, without having to manually re-texture the coat. Disappointing, but not a dealbreaker.
    Thanks, Richard.
    Edit: Amended bug report to show "Solved" status.
  • HavosHavos Posts: 5,701
    Thanks, Richard.
    With the coat loaded on Edward save as a Material Preset, and then you can use this with any non-G8M characters.
    Excellent suggestion, Havos. Thanks!
