Where is she?
krs4607krs4607 Posts: 0
I started creating a female character about a week ago. I had all of her attributes set, locked, saved them and now when I pull up her file everything reverted back to original settings. The file sizes have increased from the original character to the different characters I saved of her along the way. What do I do now?
    Did you save it as a single scene or separate components?
  • krs4607krs4607 Posts: 0
    Not sure what those mean so I'll take a guess at what you are asking. I saved my character in different stages of alteration so that I could have a few copies to play around with. But each of the shaping adjustments that I made were locked so that I did not change something accidentally.
  • Richard HaseltineRichard Haseltine Posts: 111,949
    Which option under File>Save as did you use when saving?
    I didn't do it as a 'save as' file I saved it as a normal named file.
    edited June 2013
    If all you did was go to File > Save and name it in the dialogue, then you'll find it in your library in the Scenes folder. Is that what you're loading?
    Post edited by Lissa_xyz on
    Yes, when I opened the file of the three different files that I had created during various changes, all of the specs were set back to zero. However, under all three characters the file sizes are different for each.
