Daz Install Manager items not showing as installed.
bobmale
I had to install everything from DazStudio on a new computer. I started with Daz Install Manager. I installed everything that DIM had to offer me, but when I'm in the Contents Libary products in Studio I still find a lot of items not installed. How do I get the two seeing eye to eye again?
This isn't the Smart Content tab. I also tried reimporting the metadata and a couple of other things. I've been days at putting everything back together.
Also, because of this I cannot Auto-Fit warbrobe items between figures to the usual full extent. "What figure was the item originally designed for?" is a shorter list now. What is the name(s) of the product that does that? For instance I can't put G2 items on Genesis.
That sounds as if you may not have DS set to use the folder DIM is isntalling to as a Content Directory. Have you changed the default locations?
Yes, I have to. C:\ is small and meant only for Windows not nearly 1 TB of Daz files.
That said, initially it saw the DIM files, but at some point stopped seeing them. I added all of the folders to the list in the Content Directory Manager. I just changed the drive letter for each path.
And did DIM install to one of those folders?
By the way, all those sub-folders of the My Daz 3d Library in Poser Formats are a bad ideas, they are likely to cause issues with saved scenes. You should not have both a folder and oen or more of its sub-folders set as a content directory.
Remove the .../Content .../Poser .../Presets .../Runtime/Weblinks/Affinty path as they are nested libraries and won't work. What exactly is the install path in DIM?
My DIM installation folder is "D:\Users\public\documents\My DAZ 3D Library". I added it to the DazStudio Formats list. I trimmed some of the others the way I thought was suggested. Now I have the new folders as attached.
I did a couple of things to try and get the items scenes. Stopped and started CMS. Re-imported Metadata. I think something else but with all the setting flipping I'm not sure. I think reimporting did it. There are some broken duplicates but I can handle that.
My Auto-Fits are back, though I still don't know what they are called to prioritize their install the next time I have to rebuild. Any idea?
I'm grateful for the help thus far.
I'd really like to streamline things further. Suggestions? Can I merge the "public" and "bobma" My DAZ 3D Library folders? Is there a way to tell what is needed for the Poser format folders? Things are even more confusing in the backend because I wanted to hang onto some old products and couple from other places than Daz3D.
The Genesis 2 to Genesis products are
https://www.daz3d.com/genesis-2-female-clone-for-genesis
https://www.daz3d.com/genesis-2-male-clone-for-genesis
Yes, you can merge content directories. You can also merge the Poser form,ats folders, where they are different.
Thanks Richard, and everyone else. Slowly I'm getting re-installing to be less painful.
I'm keeping loads of the DIM installs to cut down on downloading. That takes up some space for sure.
