Script?
Hello,
I just bought the Scene Optimizer (https://www.daz3d.com/scene-optimizer) and I saw that I need to go to the script, but I don't have any tab like that...
Also I found on a post https://direct.daz3d.com/forums/discussion/168746/missing-tab that I need to somehow active that one... but I'm not sure how to do that? Could someone explain to me? How can I get the script working
  • nonesuch00nonesuch00 Posts: 18,910
    I don't have that product but usually scripts are in the top level of your DAZ Content Library in s directory called scripts in another directory usually named after the PA Vendor, in this case V3Digitimes.
    Then when you locate the script you want to create a menu item for, do as Richard Haseltine says in that thread you linked too.
  • If you installed via DIM it will be in the Content Library pane under
    Daz Studio Formats>My Daz 3d library>Scripts>V3Digitimes Scene Optimizer
    (where My Daz 3d Library should be repalced with the name of the content directory tou installed to).
    Regardless of how you isntalled, it will be in a category list under
    Utilities>Scripts
