Help on adding a texture/material
chadjohnsonceejay
hi i have a custom complete outfit but their is n texture added onto it how do i add materiel into it?
chadjohnsonceejay
Select the outfit in the scene and open the Surfaces pane. Look if there is/are Surface/s available and if so select them all.
Next change the viewport to UV View and look if there is any UV-Map (some 2D mesh) in there.
If so create an UV-Template - have a look at here Creating UV Templates.
Load that UV-Template into an image editor and paint your texture on a new layer over the places where the UV-Template shows the mesh.
Similar thread:
My obj files are silver color (Kind of like a pewter object) when I import them into DAZ.
