Can't apply Iray Uber Base Shader
Noah LGP
Hi,
1 object with 25 sufaces, I applied Iray Uber Base Shader to this object :
- 14 surfaces became Iray Uber Base Shader
- 11 surfaces are still DAZ Default Shader and can't be replaced, it only changes the settings not the shader.
How to force the conversion ?
Post edited by Noah LGP on
I've not come across that before. Does reloading the object work normally, or saving that oen and restarting DS?
I opened/closed Daz Studio several times today.
The object is dystopia 6x6 from Dystopia City Blocks 001-010, I had no issue with 011-020 Blocks.
011-020 use the same surfaces, I saved and loaded the material preset but Daz Studio can't still replace Daz Default Shader.
Yes, I see this - it will let me apply soem other presets, for 3delight shaders, but not the Iray uber base. please make a bug report on this https://www.daz3d.com/help/help-contact-us
Ah hah!!! I'm not the only one! Thanks goodness I found this thread, I thought I was going bonkers. Exactly the some problem - I cannot load Uber Base Shader (or any iray shader) onto a number of surfaces in the Dystopia 6x6 from Blocks 001-010.
Okay, off to make a bug report. I just thought I'd post in case any other poor soul starts searching forums in middle of the night trying to figure if they were going insane.
Thanks!
