Shaders Not Working
I do not understand where the problem is
My Comp.
iMac (Retina 5K, 27-inch, Mid 2015), CPU : 3,3 GHz Intel Core i5, Memory : 8 GB 1600 MHz DDR3, GPU: AMD Radeon R9 M290 2 GB OS: MACOS High Sierra 10.13.3
  • scorpioscorpio Posts: 8,533
    Make sure you have the object and the surface (Surface Tab)selected before applying a shader, and some won't show until you render.
  • IceDragonArtIceDragonArt Posts: 12,899
    Yes, it looks like you don't have the object selected in the surfaces tab.  Usually you have to have it selected in both the scene tab AND the surfaces tab for most shaders to apply.
  • sunaysunay Posts: 1
    Yeah right .. the problem is that I can not pick anything on the surfaces tabs .. pop-up menu is not active ..
    Go to
    Windows >Panes(Tabs)>Surfaces
    this will bring the surfaces tab up,
    using the surface selection tool also helps in selecting the surface and the object.
    520 x 281 - 22K
