Exalted Magical Materials Shaders
DaWaterRatDaWaterRat Posts: 2,887
edited September 2013 in Freebies
I've fixed some minor issues with the shaders, and added a couple more.
http://www.sharecg.com/v/71898/browse/21/DAZ-Studio/Exalted-Magical-Materials-Shaders-Updated
Okay, so Exalted 3rd Ed is due out this fall, and the Kickstarter is going very, very strong.
So I decided to make some shaders for the Magical Materials using the new Subsurface Shader base.
I haven't tested these on a computer other than my own, but it should be set up correctly.
http://dawaterrat.deviantart.com/art/DWR-Exalted-Shaders-376284558
Or
http://www.sharecg.com/v/69666/view/21/DAZ-Studio/Exalted-Magical-Materials-Shaders
Enjoy.
1000 x 750 - 274K
Post edited by DaWaterRat on
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,310
    Thanks very much :)
  • KeryaKerya Posts: 10,943
    Thank you so much! :)
  • DaWaterRatDaWaterRat Posts: 2,887
    Glad people seem to like them. :)
  • DrakenhawkeDrakenhawke Posts: 48
    Are these subsurface shader compatible? Any tips you could pass along on how best to use them (lights, materials, etc.)
    They're presets using the AoA Subsurface Shader base, so if that's what you mean by subsurface compatible, then yes. :)
    I've used them mostly in scenes with fairly direct lighting so far. Having some sort of back light shows off the subsurface features best (most useful on the Orachalcum and Soulsteel, if you're trying to use them as such.) I'm not sure what you mean by recommended materials. Since I designed them for use with Exalted character art, I've mostly used them on armor, weapons and jewelry.
    I did neglect to adjust the displacement, but I've also found it somewhat useful if you want to add some sort of bas relief or engraving.
    800 x 1000 - 474K
    800 x 1000 - 407K
    800 x 1000 - 615K
    Simply amazing. I will try it and post images when I have some.
    Update in first post. Added 2 new materials, and fixed some issues with the old ones.
    Thanks :) :)
  • StratDragonStratDragon Posts: 3,290
    a new set of shaders is always a good thing.
    thanks!
