Quick hint on muliple monitors with mulitple resolutions (Windows 10)
bshugs1525871bshugs1525871 Posts: 184
Hello,  I may be the only one who's had this issue, but on the off chance I'm not here's something I realized:
If you're having problems getting tabs to anchor where you want them on a second monitor, the issue might be due to the Scaling setting in Display Settings.  If the monitors are using different settings for Scaling, the tabs will seem to jump sideways or move off-screen when you drag them off the main monitor.  I'm guessing this is because Daz Studio is using the main monitors Scaling settings, which are exaggerated on the second monitor.
The solution is to use the same Scaling settings on both screens.
Here's a screenshot of the Display Settings
:image
The only disadvantage is that the text on a 4k monitor can seem a bit small, and this is a global change, affecting all applications.
If anyone has additional information or advice about this, I'd be glad to hear it.
1802 x 1397 - 169K
Post edited by bshugs1525871 on
