DAZ Studio interface colors
Is it possible to change DAZ Studio UI colors?
Currently user interface is too dark, especially in parameters - digits can be hardly seen:
414 x 397 - 33K
Yes, you can pick a different stype from Window>Style>Select Style. You can also change the colours of elements defined in as tyle with Window>Style>Customise Style, though you need to be careful to ensure that the colour choices don't make things blend together.
Thank you very much!
Also, keep a note of the original settings of any changes you make. It's not always obvious which other UI bits and bobs actually share the colour you're changing — it's a bit too easy to make one change and end up with either the dreaded "angry fruit salad", or finding yourself in a daisy chain of "just one more change to this setting will (finally!) fix things".
Thanks for this. Somehow I've been using DAZ for years and never discovered how to change the color scheme. I find the default (dark scheme) very hard to read. Might be why I overlooked the menu option allowing you to change it up.
