Help to save render setting
0oseven0oseven Posts: 626
Hi
(Sorry I think I answered my own question - see my EDIT - but left it here anyway)
I am finding "render settings" I save do not change anything when I reload.
By clicking the presets icon in the render room's "rendering" pane it brings up the wizard and loading these carrara presets work ok.
If I save" my ' setting using the "save "icon, to the same folder the file also appears in the preset wizard window but changes nothing when i load it.
so far have not found any clues in the manual or forum.
Any suggestions would be appreciated.
Using version 8.5.204 64bit
Edit
ps I was expecting "output" settings to be saved as well but apparently not
Further test revealed that "Render" settings are being changed but not "Output " ie I would like various settings of width, height, DPI and even specify current frame or movie and format to be saved. These are things I change frequently to see how things look at different resolutions.
Would be nice if Carrara provided some drop down presets of common resolution settings.
So now just inviting comments
  • HeadwaxHeadwax Posts: 10,536
    edited June 2013
    hi for setting stuff carrara doesn't save like toon render settings (???? I think this was it) I have been doing screengrabs of the render settings so I can at least mimic them later
    if only by hand ;)
    Post edited by Headwax on
    Needs to be a feature request for sure. I never realized it wasn't part of the render settings...
  • ManStanManStan Posts: 0
    I griped some time way back about no way to save render settings except as a scene.
    Actually, that is how I have dealt with it..., having several starter scenes that are empty with all my presets in place...
  • 0oseven0oseven Posts: 626
    Thanks for feedback.
    I've felt for a long time there was a need to provide something better.
    So what about if peoples specify their needs or idea of how the "saving" should be implemented ?
    I'd like to see a drop down to insert preset resolutions - what sizes do you think thay should be ?
    I'll then collate it into something to send Daz as a Feature Request.
    honestly..., I'd rather they make it easy for us to add them ourselves.
    Everything within the output window needs to be saveable: width, height, aspect
    Print: 200dpi
    2 x 3in (business card)
    4.15 x 6.25in (postcard)
    Photo 150dpi, 200dpi, 300dpi ?
    5 x 7in
    8 x 10in, 10 x 8
    11 x 14in, 14 x 11
    20 x 30in
    etc
    video
    640 x 480 VGA
    720 x 480 0.9 - 1.2 aspect (DVD-NTSC)
    720 x 486 0.9 -1.2 aspect (D1-NTSC)
    720 × 576 (DVD-PAL)
    1280 x 720 HD-720p
    1920 x 1080 HD-1080p
    digital cinema
    2048 × 1080 2K
    4096 × 2160 4K
    8192 × 4320 8K
    Monitor
    640 x 480 VGA
    1024 x 768 XGA
    1280 x 800 UXGA
    1920 x 1080
    1600 x 1200
    http://en.wikipedia.org/wiki/List_of_common_resolutions
    Should the OUTPUT settings be " saveable" along with the RENDER settings or seperate. ?
