Aligning the translation tool
How do you align the translation tool with the object. Too often I find it does not align with the center of an object making it hard to pose. This is particularly true when the tool is somewhere outside of the actual object I need to pose and not visible when fine tuning a pose. Or is for instance in the middle of the sword when I need it at the hilt.
  • y3kmany3kman Posts: 877
    Joint editor (move the green widget to where you want the center axis)
    -or-
    create a null and parent the item to it
  • If it's a figure, make sure it hasn't been translated with the hip (or whatever the root bone is) when you are trying to use the figure node.
  • cclesuecclesue Posts: 420
    So what does the red widget do? should I also move that on?.
  • The red is the end point, if this is using the Joint Editor.
    I'm not clear on what the "end poin" is. Is there documentation that explains all of theis?
