How to export high bit-depth images from Studio (?)
Is there any way to save images from Studio in bit depths higher than 32? 16 bpp would be much better for compositing but if the option is there then I haven't found it yet
For Iray you need to use the Canvasses feature (sub-tab in the Advanced tab of Render Settings) - click the + to add a Beauty Pass and when youn save the main render as MyImage a folder will be created named MyImage_Canvasses which will contain an .exr version of the render. As far as I know it isn't possible to get higher bit-depth images from 3Delight.
Thanks Richard. I will try that out.
