Help, my renders are white
I'm not sure what happened, I tried to render in Iray with an hdri background and first it was fine but then daz needed to close for a fatal error and now when i render in iray it looks all washed out like a high beam light. does anyone have a clue? thank you ahead of time.
1680 x 1050 - 541K
  • TheKDTheKD Posts: 2,711
    First thing I would check is under render settings > tonemapping. Check that the ISO is not really high, and that the fstop is not really low.
    Also make sure the camera headlamp is OFF (if you're using one).
