Individual Props per Animation Frame?
If I were to use an effect, like say, underwater bubbles, in an animation timeline, and use individual props per frame to allow for the effect, is there a way to change the prop, cancelling the prop from the last frame out?
  • AscaniaAscania Posts: 1,856
    edited February 2018
    Point 1: It's a bad idea. A single frame is far too short a time.
    Point 2: It's a bad idea. Far too much wasted effort. Turn off visibility for the prop when it is not to be seen and then move and re-use it elsewhere.
    Point 3: Basic keyframe animation. There should be a couple of tutorials for that floating around here somewhere.
    Post edited by Ascania on
  • nonesuch00nonesuch00 Posts: 18,890
    You'd put the bubbles in and move them from bottom to top with slight side to side motion per keyframe. You'd want that as a track separate from humans, fish, anenomes, and so on...
    That should be the easiest thing you animate
