How to replace default UVs?
Hey folks
How can I replace UVs of a model? I tried to use Update Base Geometry, but it didn't replace the UV. I tried the load Uv, save Asset method, but it ruined the model.
Hey folks
How did it ruin the model? Loading a new UV set would be the usual method. You could also try loading the new OBJ and using the Transfer Utility to rig it if you simply want to change the default.
