Johan for M5 - Now available [Commercial]
Male-M3diaMale-M3dia Posts: 3,584
edited December 1969 in Daz PA Commercial Products
Johan for M5 is a charming rogue with multiple looks. Johan brings a handsome man, with a sweet, angsty smile to all of your renders.
Johan features nine custom face morphs, representing facial features of men from different ages. You can use them individually, or mix a percentage of each to make your own custom morphs. Use your creativity by starting off with the base and applying morphs to see what you can come up with. He also features five beautifully sculpted body morphs to mix-and-match. Johan comes with a high resolution, realistic texture, as well as hair and bald options. Also included are highly detailed arm sleeve tattoos to add a more rebellious look.
1000 x 1300 - 733K
700 x 910 - 217K
700 x 910 - 270K
700 x 910 - 225K
700 x 910 - 251K
  • Proxima ShiningProxima Shining Posts: 969
    edited June 2013
    Very, very impressive!
    Post edited by Proxima Shining on
    ^Thanks!
    A few more before I head off for lunch...
    1000 x 1300 - 159K
    1000 x 1300 - 246K
    1000 x 1300 - 370K
    1000 x 1300 - 125K
    1000 x 1300 - 331K
  • Thadeus72Thadeus72 Posts: 415
    look excellent
    very versatile
    i like the older character loke one with the stache and the unshaven
    i hope getting him soon
  • Chou-VertChou-Vert Posts: 122
    edited June 2013
    I just purchased Johan, I like him very much. One little issue I'm having, I don't know if it's just me. When you apply the default body material, the textures inside the mouth disappear. I can fix it if I apply the mouth texture manually (there seems to be two, names are similar, one seems to work the other doesn't). I found that the bump map and specular are applied, it is just the diffuse texture that seems to drop out. I was using Michael 5 as my base figure.
    Thank you,
    PizmoSF
    Post edited by Chou-Vert on
    ^I asked someone to look at this to see if it can be duplicated.
    Anyway, a few more quickie renders I made:
    1000 x 1300 - 100K
    1000 x 1300 - 363K
    1000 x 1300 - 722K
    Ok, I sent a mouth update to QA this morning so they should look at it soon.
    Another quick render:
    1000 x 1300 - 369K
    Thanks so much. I'm working on my first Johan render as I'm typing this. I love him. You do great work, your characters are always so alive.
    A grateful fan,
    PizmoSF
    Thanks.
    I try to put a variety of characters in each pack, because I remember the M4 days of people complaining because there were no older or younger characters available to purchase.... or they were all one size and you couldn't change it unless you did some voodoo with stephanie4. So with no teens 4 or David 4, you were really didn't have any options for this; so Genesis opens up so many possibilities with characters, especially for those that render males. And of course you can mix or dial a partial percentage of the morphs in to create your own characters so there's a lot in here to play with.
    This product also has a bit more under the hood as well; there are some JCMs in the hips of each body type to aid with bending. Some of it is subtle, but you see the difference as you bend his thighs or move his leg backwards or sideways. So our products are a bit more than just a head and a body shape and takes a bit longer to produce.. but the result should be characters that look and pose a bit better in your renders.
    Anyway, here's two more renders I put together over martinis ;)
    1000 x 1300 - 203K
    1000 x 1300 - 368K
    The hair in that last one says the martinis really kicked in by then. =P
    Hey! I had to use my Hiro 5 clothing sometime! ;)
  • ForbiddenWhispersForbiddenWhispers Posts: 1,437
    This is an artistic promo I did with Johan. Just playing around.
    700 x 910 - 161K
  • nemesis10nemesis10 Posts: 4,028
    May I ask what hair was used in the Top picture? It looks very familiar...
    Since I see some of my stuff on today's promotion, here's the Johan skin on the Los Monstros and Tweens products in my store...
    1000 x 1300 - 297K
    1000 x 1300 - 357K
  • bohemian3bohemian3 Posts: 1,035
    Fantastic textures. Fantastic Morphs. Really superb job on these for all involved in the production team. Used the textures and Daniel morph for one of the PC contest.
    Again thanks. Especially good job on the SSS map - would love see you produce nomal maps as well - they work really well in 3ds Max's Mental ray renderer and sss shaders! But as is, superb!
    1280 x 720 - 492K
    Very cool.
    Did a quick render to show that the shorter body can be mixed in to get a good companion for Stephanie 5 as well. The Steph is from my Girls of Summer pack that's part of the promotion for a few more hours...
    1000 x 1300 - 279K
    Yeah, I've been doing too many morphs...
    My next set uses Johan's skin.. (which is coming soon)
    This is the Caleb morph.
    1000 x 1300 - 233K
    Very nice!
    Another quick render of Johan's skin and a morph from M3D Men 1...
    1000 x 1300 - 437K
