Genesis Basic Female always at 1.00
WinthrodWinthrod Posts: 66
I have DAZ Studio Pro 4.6 and about a week ago I noticed that that no matter what figure I loaded in the 'Shaping' tab the Basic Female is always at 1.00 when I load a character. Even loading the Basic Male both the Basic Male and Basic Female are both at 1.00. Doesn't matter if it's M5, V5, H5 or A5 every Gen 5 character loads with Basic Female set to 1.00. Admittedly I haven't tried any Gen 4 characters recently.
Anybody have any ideas why or how to fix?
    edited June 2013
    Sounds like your main Genesis file might be borked. I think Genesis is included in the starter essentials rather than the program itself. Try reinstalling the Genesis Starter Essentials.
    Post edited by Lissa_xyz on
  • WinthrodWinthrod Posts: 66
    Thanks for the quick reply Vaskania! I will give that a try.
  • murgatroyd314murgatroyd314 Posts: 1,567
    This is something that occasionally happens when you use the wrong save option with a morphed figure. The result is that the morph file is resaved with a default value other than zero. Reinstalling generally works, or you can use this manual fix:
    Locate the offending morph file (e.g. My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicFemale.dsf)
    Open it in a text editor.
    (If it's gibberish, rename it to .zip, unzip it, rename the resulting file to .dsf, and open that one.)
    Find the line that says "value" : 1, (or possibly some other nonzero value)
    Change the 1 to a 0. Make sure you don't do anything to the space before the number, or the comma after it.
    Save.
