Suppressing detail
So I am trying to create a toon character using the base genesis 3 maps as a starting point . What I want is some way to be able to suppresss all the unnecessary details alreasy present in the base skin . Is there some way I can do it without having to use something like photoshop(not too good at it)??
  • MarcCCTxMarcCCTx Posts: 947
    edited February 2018
    Could you just change the shader? These are both Genesis 8 Male. One with PW Toon.
    600 x 388 - 93K
    Post edited by MarcCCTx on
    Or here's applying PW Toon (White) but keeping the original surfaces.
    600 x 388 - 118K
    Sorry for sounding like a noob but what is pw toon?? Is it a product I can buy ? Also I would still like to persist with my original question about suppressing skin details in base skin and color variations in the base skin maps.
  • Oh hang on are these inbuilt toon shaders? No I discarded those as just not good enough.
  • LeanaLeana Posts: 13,317
    pwtoon is a set of shaders for 3DL: https://www.daz3d.com/pwtoon
  • But these are only limited to 3DL right . That is not a small limitation for someone wanting to work primarily in iray.
    True, but if you're going to do toon work, it may be better to consider 3dLight, the iRay renders really aren't as well designed for that type of work.
  • Then I would need to start learning how to work 3DL properly . That is definitely not what I want to invest so much time in.
  • Thank you for the help by the way.
  • nonesuch00nonesuch00 Posts: 18,863
    It you want a true toon style than pwToon is what you want but if you want a claymation toon style (eg Pixar Toy Story) then you want the Sketchy product linked above.
