Backgrounds
Couple of things I need to know please.
I seem to remember I used to use backgrounds quite a lot when I was a Poser user, but I have never used them in Daz, so first question is how do I use backgrounds in Daz? Can anyone point me in the direction of Idiots Guide Tutorials or similar.
Now what brought this thread about is, High Polycount. So, I thought, what if I loaded the empty room I needed, set up the angle for the pose, render it, and maybe save it in a format that can then be used as a picture background. Then load my characters and bits into the scene. Would this be possible? Would it not reduce my polycount considerably if it can be done?
Thanks in Anticipation
  • BeeMKayBeeMKay Posts: 7,019
    edited February 2018
    You can add a background in the Environment tab. If that isn't open, you can find it under Window--> Pane.
    In the tab, you have a dropdown where you can select the type of background (dafault: none). I hope that helps, if not, I am not at my render PC, so you'd have to wait a few hours until I can get screenshors done (or some kind soul drops in with a tutorial)
    Post edited by BeeMKay on
  • Bunyip02Bunyip02 Posts: 9,345
    1. Click on Window tab, then choose Panes (Tabs)
    2. Go down the list and click on Environment
    3. In the Environment window that has popped up, change Type - None to Backdrop
    4. Click on the Background icon and locate the image you want for your backdrop.
    You can also use the Rotation and Flip as neccesary.
    1899 x 1044 - 2M
    Post edited by Bunyip02 on
  • Thanks to all. I'll get stuck in there now.
