Skin compatibility
PhiloppPhilopp Posts: 294
Hello,
if a skin is compatible to M3, or requires M3, can it also be used on M5?
Thanks for the answer.
P.
    In the main Skins only for the generation they were made for,
    Gen 4 skins can be used on gen 5, if you use the relevant UV set, but Gen3 was done is such a radically diffrent way on the UV map that afaik there is no way they can be used.
  • BWSmanBWSman Posts: 0
    You would need to use Texture Converter 2 to convert the skin to M4 (or V4) and then apply it to Genesis.
  • PhiloppPhilopp Posts: 294
    edited June 2013
    Hello,
    at first thank you very much for the answer. And sorry for to be such a noob. Just so that I understand it thoroughly, the next question:
    If a hair or cloth is said to be compatible to M4, can I use it on M5 or on a Genesis figure?
    Thank you very much for your patience and for your help
    Greetings
    P.
    Post edited by Philopp on
