Will 4.6.0.18 64 bit open files created with 3.1x 32 bit?
areg5areg5 Posts: 617
I recently switched from a windows 7 32 bit system to a windows 7 64 bit. I used pc mover to move all of my stuff over including Daz 3.1, which has been my workhorse. It works fine on the new computer and reads all of the files I created. Content moved over fine. I then loaded the latest version 4.6.0.18 64 bit,, and I had a lot of genesis content I loaded as well. Works fine.
However, the 64 bit version won't load the 32 bit files. Crashes every time. My question is is that fixable? The content directories are set up the same in both versions, and the 64 bit version can load all of the figures normally, it just won't load the saves from the 32 bit system.
I should mention that for a while I played around with the 32 bit 4.5 on my previous computer, and I loaded the 3.1 files normally (just crashed while rendering
  • fixmypcmikefixmypcmike Posts: 19,710
    Do you get a crash report or any error messages? I haven't had any problems opening DS3 files.
  • areg5areg5 Posts: 617
    Fixed, it works now. It was just a matter of having the libraries listed in the exact same order. Renders very fast compared to 3.1, and doesn't crash.
