Some dForce questions
Ok so i read that clothing/items must be 'dForce ready' for dForce to be used.
I will illustrate my question with an example.
I have a towel wrapped around a female body. With the breast hugging this gives a horrible/unrealistic effect. This can be solved by using fit control, however this isnt always 100% accurate in some cases. Marvelous designer is also used a lot but for something simple as a towel ... I dont want to get and learn another program
Is there a towel like https://www.daz3d.com/h-c-shower-towel-for-genesis-3-female-s with dForce and can dForce be used to remove that effect. (Is there a tutorial available)
Or am i better off ussing my model and towel and still use Marvelous designer?
  • LeanaLeana Posts: 13,666
    Just to be clear: you can add dForce properties to any existing mesh yourself. Depending on how the mesh is built it may or may not work well when simulated, but you're not restricted to content sold as dForce compatible. Those simply have dForce properties already set and have been tested so you know they should work well.
    Ok then i really need to delve in deeper in the dForce engine then. I so hate the whole breast hugging in clothing but its normaly so much work to get it right. Fit control does a lot but isnt always acurate or needs so much tweaking that MD is faster. Will give it a go this weekend. I will post the results here.
