Can Genesis and Michael 5 wear the same clothes?
cav8000cav8000 Posts: 0
I need to know if I buy clothes that are compatible with Genesis, can Michael 5 wear them too or will I have problems getting the clothing to fit?
  • frank0314frank0314 Posts: 15,100
    Yes all clothing made for Genesis will fit its various shapes.
  • scorpioscorpio Posts: 8,533
    With reservations, some things will deform and some things will break it depends on how well made they are.
  • Scott LivingstonScott Livingston Posts: 4,352
    This is true...but usually it only breaks with the more extreme shapes (if it breaks at all), not with regular-people shapes like Michael 5.
    Some clothes contain custom morphs to ensure a perfect fit for various characters. If the clothing doesn't contain the same morphs as the character you're using, it will fit using "Auto Follow." In general, the closer the shape is to the basic Genesis shape, the better the results will be.
    Depends on what you mean by "problems," too. Minor pokethrough (the figure poking through the clothing mesh where it's not supposed to) is not an uncommon situation, but there are various ways to fix it. Which method is best depends on the situation, but you can pretty much always find a solution. Some methods are discussed here: https://helpdaz.zendesk.com/entries/21178872-Eliminating-Poke-Through
