UV Mapping and retaining morphs
2getit2getit Posts: 0
After messing with a few morphs on a prop I've noticed that its causing the texture to stretch extremely bad due to bad uv texturing, I want to re UV map the prop, should I export the prop out as an obj with or without the morphs already applied to c4d? And when I import it back into daz can I still edit the morphs?
  • Richard HaseltineRichard Haseltine Posts: 111,965
    It's not really bad UV mapping if it stretches when morphed. You will find it easier to see what you are doing if you remap the morphed OBJ - DS doesn't care about the shape when loading a new UV set, just that the vertices are in the same order and polygons still made of the same vertices (and that the material groups match).
