Monster Pack 6 - Missing files and DIM
SloshSlosh Posts: 2,391
Just installed Monster Pack 6. The DIM does not install Cliffhanger (does install Cliffhanger StudioCF) and the DIM does not install Overlook Ward Ps. I manually downloaded and installed both of these files. Cliffhanger ends up working just fine, I only wanted to point out that the DIM does not install it. Overlook Ward Ps installs, but is missing texture files for the radiator and strip lights when using the "!The Overlook for Ward.daz" preset. I do already own WestParkWard and the lights and radiators load fine, but the textures for Overlook are not present, so I get a pop-up asking me to locate each texture. Everything else works just fine.
In case you are wondering, I refreshed DIM, closed it, reopened it, etc. The two files just aren't pulled in by DIM.
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,989
    Will get Jen to look into it.. thanks for the heads up :)
  • JGreenleesJGreenlees Posts: 2,249
    edited May 2013
    I downloaded the dim files and they have the textures can you post an image or text of the error so I can see it? It seems to be loading fine for me. Remember that this set (overlook) requires west park ward, west park, legacy and the Overlook (Since some of the textures are used from it (it wasn't showing as required on the page but i hope i fixed it now)
    As for Dims not showing I am looking into that now.
    Jen
    Edited to add that I checked the bundle and everything is showing in dim. With all the correct files. Can you file a ticket if you aren't seeing all of them. Make sure you didn't already have it downloaded in DIM as it won't show files you've already downloaded.
    Jen
    Post edited by JGreenlees on
