can you fasten a sign to a moving door?
Wanted to add a sign to a revolving door but of course when I put the sign on the door it just stays stationary whenever the door is moving and doesn't move with the door. Is there a way to fix it to the door so it stays on the door as the door moves?
  • it has to be rigged to the door
    without knowing the specifics of the door used I cannot say if as simple as parenting or using the transfer utility to do it.
    simple parenting the pivot point is important
  • ToobisToobis Posts: 993
    hmm ok can anyone perhaps give a basic tutorial if its at all possible?!
  • macleanmaclean Posts: 2,438
    If the door and sign are 2 separate props, you should be able to just parent the sign to the door and it'll revolve with it.
    In the scene pane, highlight the sign and drag it onto the door to parent it.
    reread what I typed
    it depends on the specific door and nobody has any way of knowng that unless you link to a specific product and they have it
    a simple prop yes parenting is fine, a rigged door it can vary and a morph based door movement all bets are off (in DAZ studio at least I can do it easily elsewhere)
    K I think I got it working anyway. Thanks guys.
