Wrong breast morph or shape loading
TheKD
Something is wrong with my G8F, I am not sure how to pin down what it is though. No matter what character I load up, it is coming in with breasts that seem too large. I check under currently used section for shapes and parameters, nothing there. What else can I look for to find the offending install?
Strangely I have a similar issue with G2M, comes with a body morph dialled in which does not show uo under 'currently used' so I have to go find it under the shaping settings, looking for a morph that is at value 1. I susepct it is not being flagged as used as it has not been dialled in since the laod of the figure.
I just tried going through the chest section in shapes and parameters too, didn't see one with a 1. Maybe it's just my eyes? Here is ravyn for example, looks a lot bigger to me than the promo. Is that normal, and it's just a matter of the top making her breasts look smaller? I am just starting to migrate over from G3 to G8 now, so I have not really used G8 much.
Try enabling Show Hidden Properties in the option menu (the lined button in the corner or right-click the tab) and then look at Currently Used.
Oh yeah, I always have show hidden on, the only ones showing up in currently used besides Ravyn morphs is navel, turned it off to make sure it wasn't affecting the breasts, it's only doing what it should be, making the belly button.
Don't just check the chest section - you may need to go through all areas as it may be a full body morph doing it.
Yeah so far scrolled through chect, full body and people, not seeing anything dialed up. Is there a term I could search for in the duff with notepad? Oh hmmmm, genesis 8 seems to be a dson file, and not a duff :(
I don't think it'd be in the duf file as that'd suggest something altered the G8F duf and I suspect that'd be bad! I don't think there's an easy way, apart from just looking and looking, to find something liek this. I knwo the name of the figure that is screwing up my G2M and yet uasing that name as search term in filesystem (under /data) and in Daz Studio content I find nothing!
Ah, I was hoping to find something easier than scrolling for two hours lol. I remember with G2F and G2M I had some freebies mess everything up like this. For G3 and G8 I have avoided freebies like that plague. It's very annoying to have to do this troubleshooting lol.
I feel your paina nd sympathise. Have you tried uninstalling G8F and re-installing in case that cleasr the auto-use of the morph? I have a feeling it won't but you never know!
Haven't yet, but I guess it's worth a go. If that don't work, next gonna remove my G8F directory from the list, install a new one and see if it's any different. Gonna kinda be pissed if I have to install one by one to find the offending install lol. I just got done scrolling through every paramater, couldn't find a non zero there.
Did you check the DS log ?
It often helps to find strange things going on :-)
Well I tried both those things, she still loads the same with just G8 essentials and her installed. I assume if the directory is not linked anymore, studio would not be pulling a bogus morph from there anymore. Maybe it is just my eyes? Anyone else care to render ravyn in a bikini? lol
I get a couple of "Could not find output property for formula: " errors, but I am used to seeing those since G1 lol. None of them are about breasts, a couple about a lip, and a couple about a foot fix.
See image for what I get when loading G8F Base compared to Ryan and log.
Hmm, maybe it is right then. When loading her up on top of normal g8 like you did, it looks about the same amount of ravyn popping through g8. The promos seem like she is more of a tween than a teen to me.
Guess I just found a few DS bugs LOL
The right one in the pic should be a instance of Ryan but it did not scale right and strange things happen that instances could not be moved anymore or disapper then :-/
Ah, I thought the one on the right was a 30% or so dialed in ravyn lol.
