Zero y of figures & props.
Rod Wise Driggo
in The Commons
I do have a problem. If I place a figure in the scene, it's usually placed on the floor. If not, I can correct via Y-translate-dial or shortcut. But if I add stuff like a prop to the scene sometimes the prop get's placed correctly on the floor but the figure floats above. Now if I try to manually correct Y of the figure, everything starts to float. What am I doing wrong. This is for a scene without specific environment. Thanks!
Which floor - the one in the iray environment dome? In render Settings, under the environment group in the Editor tab, you can set teh Ground Position Mode to Manual instead of Auto and adjust it.
