Importing models doesn't show up
I got daz studio since I am unable to use Blender.
Whenever I try to import models like OBJ, I get the OBJ import options and I mess around a little bit trying each setting but when I accept the changes, no model is put into the viewer.
No matter if the scale is 1%, 100% or 10000%, it still doesn't show up.
532 x 197 - 13K
884 x 422 - 43K
1915 x 875 - 103K
Is it listed in the Scene pane? if it is, select it there and then hiot ctrl F to frame the selection. If that shows the item you will at least know it is there.
You're not seeing your imported model because the Viewport seems to be actually showing your (empty) Render Library view.
Richard, didn't someone else have the same problem recently? What was the fix to that situation?
I hadn't noticed that - and I can't recall the solution, though reloading the layout (Window>Workspace>Select Layout) might help.
