Rendering with two graphic cards / rendering error / iray
Hello,
I recently started working with daz and thought it would be a good idea to add my old graphic card with a pci-express extender (gtx 460 1GB) to speed up the iray rendering a bit for small scenes. Now I have the problem that I get a render error roughly at halt-time and then daz falls back to cpu-rendering (which is rather slow in my case). It renders without errors if I use only the main graphic card (GTX 745 4GB). The drivers and windows are all up to date.
I looked in the log file but unfortunately the error message doesn't help me to identify/solve the problem. According to it the GTX 745 causes the error (kernel error/whatever that means). But strangely rendering with the GTX 745 alone goes without problems. Perhaps someone with more experience can help me or give me a hint what's wrong?
The log:
2018-02-02 22:57:46.959 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Initializing local rendering.
2018-02-02 22:57:47.694 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering with 2 device(s):
2018-02-02 22:57:47.694 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 745)
2018-02-02 22:57:47.694 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CUDA device 1 (GeForce GTX 460)
2018-02-02 22:57:47.694 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...
2018-02-02 22:57:47.740 Iray VERBOSE - module:category(IRAY:RENDER): 1.3 IRAY rend progr: CUDA device 0 (GeForce GTX 745): Processing scene...
2018-02-02 22:57:47.756 Iray VERBOSE - module:category(IRAY:RENDER): 1.2 IRAY rend progr: CUDA device 1 (GeForce GTX 460): Processing scene...
2018-02-02 22:57:48.178 Iray VERBOSE - module:category(IRAY:RENDER): 1.4 IRAY rend stat : Geometry memory consumption: 14.5104 MiB (device 0), 0 B (host)
2018-02-02 22:57:48.225 Iray VERBOSE - module:category(IRAY:RENDER): 1.10 IRAY rend stat : Geometry memory consumption: 14.5104 MiB (device 1), 0 B (host)
2018-02-02 22:58:14.027 Iray INFO - module:category(IRAY:RENDER): 1.4 IRAY rend info : Initializing light hierarchy.
2018-02-02 22:58:14.027 Iray VERBOSE - module:category(IRAY:RENDER): 1.10 IRAY rend stat : Texture memory consumption: 1.11914 GiB (device 1)
2018-02-02 22:58:14.027 Iray VERBOSE - module:category(IRAY:RENDER): 1.4 IRAY rend stat : Texture memory consumption: 1.11914 GiB (device 0)
2018-02-02 22:58:14.058 Iray INFO - module:category(IRAY:RENDER): 1.4 IRAY rend info : Light hierarchy initialization took 0.03s
2018-02-02 22:58:14.058 Iray VERBOSE - module:category(IRAY:RENDER): 1.4 IRAY rend stat : Lights memory consumption: 196 B (device 0)
2018-02-02 22:58:14.074 Iray VERBOSE - module:category(IRAY:RENDER): 1.10 IRAY rend stat : Lights memory consumption: 196 B (device 1)
2018-02-02 22:58:14.183 Iray VERBOSE - module:category(IRAY:RENDER): 1.4 IRAY rend stat : Material measurement memory consumption: 0 B (GPU)
2018-02-02 22:58:14.183 Iray VERBOSE - module:category(IRAY:RENDER): 1.4 IRAY rend stat : Materials memory consumption: 74.3086 KiB (GPU)
2018-02-02 22:58:14.792 Iray INFO - module:category(IRAY:RENDER): 1.2 IRAY rend info : CUDA device 1 (GeForce GTX 460): Scene processed in 27.046s
2018-02-02 22:58:14.792 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): out of memory (while allocating memory)
2018-02-02 22:58:14.792 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): Failed to allocate 858.636 MiB
2018-02-02 22:58:14.808 Iray INFO - module:category(IRAY:RENDER): 1.2 IRAY rend info : CUDA device 1 (GeForce GTX 460): Allocated 47.4612 MiB for frame buffer
2018-02-02 22:58:14.855 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 745): Scene processed in 27.113s
2018-02-02 22:58:14.855 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 745): Allocated 47.4612 MiB for frame buffer
2018-02-02 22:58:14.933 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 745): Allocated 848 MiB of work space (1024k active samples in 0.071s)
2018-02-02 22:58:14.933 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CUDA device 0 (GeForce GTX 745): Used for display, optimizing for interactive usage (performance could be sacrificed)
2018-02-02 22:58:17.456 Iray INFO - module:category(IRAY:RENDER): 1.2 IRAY rend info : Allocating 1 layer frame buffer
2018-02-02 22:58:17.769 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00001 iterations after 30.024s.
2018-02-02 22:58:20.222 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00003 iterations after 32.484s.
2018-02-02 22:58:20.441 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00004 iterations after 32.697s.
2018-02-02 22:58:22.941 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00005 iterations after 35.199s.
2018-02-02 22:58:23.222 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00006 iterations after 35.485s.
2018-02-02 22:58:25.534 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00007 iterations after 37.792s.
2018-02-02 22:58:26.019 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00008 iterations after 38.275s.
2018-02-02 22:58:28.243 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00009 iterations after 40.502s.
2018-02-02 22:58:28.790 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00010 iterations after 41.051s.
2018-02-02 22:58:30.816 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00011 iterations after 43.067s.
2018-02-02 22:58:31.576 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00012 iterations after 43.839s.
2018-02-02 22:58:33.529 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00013 iterations after 45.791s.
2018-02-02 22:58:34.363 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00014 iterations after 46.618s.
2018-02-02 22:58:36.087 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00015 iterations after 48.345s.
2018-02-02 22:58:37.150 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00016 iterations after 49.411s.
2018-02-02 22:58:38.806 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00017 iterations after 51.059s.
2018-02-02 22:58:39.940 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00018 iterations after 52.197s.
2018-02-02 22:58:41.383 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00019 iterations after 53.636s.
2018-02-02 22:58:42.742 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00020 iterations after 55.005s.
2018-02-02 22:58:44.086 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00021 iterations after 56.345s.
2018-02-02 22:58:45.555 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00022 iterations after 57.809s.
2018-02-02 22:58:46.664 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00023 iterations after 58.917s.
2018-02-02 22:58:51.089 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00025 iterations after 63.342s.
2018-02-02 22:58:51.854 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00027 iterations after 64.107s.
2018-02-02 22:58:56.479 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00029 iterations after 68.733s.
2018-02-02 22:58:57.214 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00031 iterations after 69.478s.
2018-02-02 22:59:01.956 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00033 iterations after 74.209s.
2018-02-02 22:59:02.269 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00035 iterations after 74.525s.
2018-02-02 22:59:07.331 Iray INFO - module:category(IRAY:RENDER): 1.2 IRAY rend info : CUDA device 1 (GeForce GTX 460): Allocated 160.346 MiB of work space (193k active samples in 0.037s)
2018-02-02 22:59:07.378 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00037 iterations after 79.630s.
2018-02-02 22:59:07.441 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00039 iterations after 79.705s.
2018-02-02 22:59:10.649 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00042 iterations after 82.908s.
2018-02-02 22:59:15.065 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00046 iterations after 87.316s.
2018-02-02 22:59:15.205 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00049 iterations after 87.458s.
2018-02-02 22:59:21.393 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00055 iterations after 93.645s.
2018-02-02 22:59:22.945 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00058 iterations after 95.209s.
2018-02-02 22:59:28.884 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00065 iterations after 101.135s.
2018-02-02 22:59:30.700 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00068 iterations after 102.959s.
2018-02-02 22:59:38.109 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00077 iterations after 110.376s.
2018-02-02 22:59:38.496 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00080 iterations after 110.748s.
2018-02-02 22:59:48.500 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00090 iterations after 120.754s.
2018-02-02 22:59:48.719 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00094 iterations after 120.982s.
2018-02-02 22:59:59.284 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00098 iterations after 131.548s.
2018-02-02 22:59:59.893 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00109 iterations after 132.155s.
2018-02-02 23:00:01.691 WARNING: cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://hpclscruffy.daz3d.com/Server/ping?SID=rg8jg040ep731qi84s47levsq0) failed: Couldn't resolve host name
2018-02-02 23:00:11.910 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00114 iterations after 144.162s.
2018-02-02 23:00:12.363 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00126 iterations after 144.618s.
2018-02-02 23:00:24.769 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 12.74% of image converged
2018-02-02 23:00:24.831 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00131 iterations after 157.094s.
2018-02-02 23:00:26.816 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00145 iterations after 159.074s.
2018-02-02 23:00:40.035 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00151 iterations after 172.289s.
2018-02-02 23:00:42.503 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 29.06% of image converged
2018-02-02 23:00:42.503 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00166 iterations after 174.765s.
2018-02-02 23:00:55.394 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00172 iterations after 187.655s.
2018-02-02 23:00:59.972 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00189 iterations after 192.238s.
2018-02-02 23:01:13.316 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 45.39% of image converged
2018-02-02 23:01:13.394 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00196 iterations after 205.660s.
2018-02-02 23:01:21.769 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.14 IRAY rend error: CUDA device 0 (GeForce GTX 745): Kernel [9] failed after 0.028s
2018-02-02 23:01:21.769 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.4 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while copying device buffer)
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.14 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while launching CUDA renderer in core_renderer_wf.cpp:807)
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): Failed to merge device frame buffer into master buffer
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.14 IRAY rend error: CUDA device 0 (GeForce GTX 745): Failed to launch renderer
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): Device failed while rendering
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GTX 745): Device failed while rendering
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while initializing memory buffer)
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.3 IRAY rend warn : All available GPUs failed.
2018-02-02 23:01:21.831 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while de-allocating memory)
2018-02-02 23:01:21.831 Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : Falling back to CPU rendering.
2018-02-02 23:01:21.847 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while initializing memory buffer)
2018-02-02 23:01:21.847 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while de-allocating memory)
2018-02-02 23:01:21.847 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: All workers failed: aborting render
2018-02-02 23:01:21.847 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while de-allocating memory)
2018-02-02 23:01:21.863 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.3 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while de-allocating memory)
2018-02-02 23:01:21.863 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while de-allocating memory)
2018-02-02 23:01:21.863 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while de-allocating memory)
2018-02-02 23:01:21.878 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: CUDA device 0 (GeForce GTX 745): unknown error (while de-allocating memory)
2018-02-02 23:01:21.878 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: CUDA device 1 (GeForce GTX 460): unknown error (while de-allocating memory)
2018-02-02 23:01:21.878 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU: using 4 cores for rendering
2018-02-02 23:01:21.878 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering with 1 device(s):
2018-02-02 23:01:21.878 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...
2018-02-02 23:15:39.046 Finished Rendering
2018-02-02 23:15:39.109 Total Rendering Time: 17 minutes 57.90 seconds
Best regards
"the video card drivers are all up to date" may actually be the problem.
Roll back to 387.92 and see if it gets better.
Ok thanks, I will try it.
Are there general problems with the newest drivers?
And on a second note, after studying the logs a little bit more it caught my attention that daz fails to allocate some memory to the GTX 460 at the beginning (2018-02-02 22:58:14.792 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.2 IRAY rend error: CUDA device 1 (GeForce GTX 460): Failed to allocate 858.636 MiB). It,s only a 1GB card but shouldn't it have enough memory to process the scene? And why does it continue to process the scene with both graphic cards if the allocation failed (Or doesn't it? I am not really sure i read the log correctly).
Best regards
