DIM wont install
Got an issue with the install manager. Trying to install daz 4.10. It goes in the ready to install tab and goes into installed as well. Then restarting DIM its back in the ready to install tab. So basically wont install at all.
Ive tried running as admin too. Same issue with the GoZ plugin. Some help needed...
very similair problem with DIM sometime ago, had to install Firefox (free by the way) doesn't seem to like internet explorer. Problem solved
pate
Running as admin is likely to create problems. Check that, with an explorer window run normally, you have access to the DIM folders in Public Documents, and that you can uninstall DS with DIM running normally (just say yes when asked if you want to allow itt o make changes).
