Re-setting a messed-up surface (solved - taken that you have Supersuite)
HeraHera Posts: 1,972
Hi!
After playing around with a lot of SSS shaders and so on, I've managed to mess up a few surfaces in a scene, and not even applying the original materials helps. The only way to fix it I've figured out seems to be to add a completely new item and pose it to the same place and shape as the 'ruined' one. Or is there an easier way? Like resetting a surface completely to 'zero'/'default' (the white thing) ??
Post edited by Hera on
  • SzarkSzark Posts: 10,634
    Well Daz Studio does have a Daz Default surface preset in the library but I cannot check exactly were it is or if it is working now. I have been having the same trouble and found what you found..yes a royal PITA.
  • Richard HaseltineRichard Haseltine Posts: 111,790
    Also applying a Poser material file or any DS preset that uses the DAZ Default Shader will set the sahder to the default, which should clear and problems.
  • HeraHera Posts: 1,972
    I found a reset surface among the supersuite stuff which works for me, but perhaps it'd be interesting to know if there's a defalt one in case someone don't have the ss. Like this Daz Default surface preset
    Load a fresh Geneisis and save out a new Material preset, now you have a reset base material.
  • Jay VersluisJay Versluis Posts: 269
    The Shader Mixer opens with default material that can be applied to any object. Here's how:
    1.) select your object
    2.) select all relevant surfaces (in the Surfaces Tab)
    3.) open Shader Mixer (Window - Panes - Shader Mixer)
    4.) it opens with a DAZ Default Material
    5.) hit Apply at the bottom right
