Little Melody Hair issue - Is this the right place?
sarah_hsarah_h Posts: 0
edited May 2013 in The Commons
Hi Everybody,
I hope I'm using the right place for questions like this. Please let me know if not.
I purchased Little Melody Hair yesterday and have installed it in PP 2012. Issue is that when the hair is added to V4.2++ it's distorted, bangs all over the place, through her eyes an things! No amount of tweaking the param will correct this. Now I've used PP for a couple of years now, and this is not just normal mis-configuration. Have a look at the screen grab.
Does anyone know what might be the problem?
Thanks guys.
Sarah
600 x 313 - 21K
Post edited by sarah_h on
  • fixmypcmikefixmypcmike Posts: 19,729
    Are you using the V4 version rather than the Genesis version?
  • sarah_hsarah_h Posts: 0
    Thanks for replying.
    I'm using V4.2, not the Genesis version. Is that why?
    I don't know how the files are named, but that looks like it might be the Genesis version of the hair rather than the V4 version. What were the names of the installers/zips you installed?
    This is the file I installed:
    15930_LittleMelodyHairVictoria4_1.0_dpc.exe
    It was a bit confusing because there were other files also:
    15930_LittleMelodyHairPoserCF_1.0_dpc
    And DSON CORE
    I did not install these files though.
    And DSON CORE
    You have the correct installer for the V4 version. The other two are for use with the DSON importer and Genesis. If you don't need them or use the DSON, you don't need to install them.
    Did you get this when conforming the hair or posing the hair?
    The problem was apparent as soon as I double clicked the icon in the library. Before any posing or conforming. Is this the right way to add the hair?
    I must admit I'm out of ideas here.
    Have you tried conforming it to V4
    It loads like that?
    Yes, I tried that too. Sounds like we're all out of ideas!? I tried loading it up with out a model and the same geometry problems exist.
    Just don't know what else to do. Hey, thanks to you for taking the time to try to help.
    Sarah
    edited May 2013
    Only thing I can think of is that somehow the installation has got corrupted along the way. Can you remove all parts of it from your runtime and then try installing it again. Maybe even using a fresh download of it as well after clearing your cache to remove any trace of the previous download.
    Post edited by Chohole on
    Yes, this seems to be the thing to do.
    Ok, so I just look for anything relating to Little Melody Hair in all Poser folders and just delete, right? What cache & where do you mean?
    Your Browser cache. Where you find it depends on whaich browser you use. I use FireFox and I find it in Tools / Clear Recent History. I then make sure that the only thing clicked is Cache
    Well, I cleared the browser cache, deleted all the 'little melody hair' files, downloaded a fresh copy of the exe file and re-installed. Any it's exactly the same.
    I noticed a couple of things this time though:
    In the readme file here:
    http://docs.daz3d.com/doku.php/public/read_me/index/15930/start
    It says, Known Issues -'A figure must be loaded in the scene for .PZ2 MAT Poses to work in Poser.'
    Does that simply mean that I need to have V4 visible on stage before it'll work?
    And in the pose library there's a 'fit base!!' along with the MAT's which mentions 'Use first to FIT the BASE to your character'. I'm not sure what this means. I did try playing around with it but i'm not sure I'm using it correctly.
    Any ideas on this?
  • loveitloveit Posts: 62
    im having the same issues,wondering if they can give us a update on it
  • ChuckMChuckM Posts: 170
    I am also having the same problems with the Melody Hair product.
    Well, I never got to the bottom it so I too am hoping it can be resolved. Any chance the creator could offer some advice?
    At this stage the only advice I can offer is to file a support ticket, using Tech support as the dept.
  • WandWWandW Posts: 2,907
    I discovered a problem with the limits of the neck actor, and sent a note off to SWAM.
    In the meantime, unhide the Fit Victoria 4 dial in the neck, and change the lower limit and the value to zero, which will fix it...
    There is an update that fixes this issue, so redownload... :)
