Posing controls limited with Real Feel Zipped Cardigan
inthanityinthanity Posts: 89
I purchased Real Feel Zipped Cardigan yesterday. It applies to character well, and all seems to be working - with the following exception: when I try to do any "real-time" adjustment for positioning and posing (translate, rotate, universal tool, active-pose, etc.) the character does not move until about 3 seconds after an adjustment is made. For example, if I were simple to try and drag the universal tool to move the character horizontal along the X axis, he will not move. If I delete the Real Feel Zipped Cardigan, then all is well for movement.
Any ideas? I am using DAZ3d Studio 4.5 pro, and I was testing it with no other elements loaded except the character and the clothing item.
  • fixmypcmikefixmypcmike Posts: 19,730
    The clothing probably has a smoothing modifier applied -- in the Parameters tab you can set that to not update every time the figure moves, and only turn it on at the end.
  • inthanityinthanity Posts: 89
    That was it! Thanks for the reply.
