Shape and Parameter Features Moved?
It's been awhile since I used DAZ Studio. Maybe even a year. In the meantime, the interface has changed. I'm currently using DAZ Studio 4.10 Pro. In an earlier version of DAZ Studio, there were options to modify hair, bodies and other things. For hair, the options used to be in the parameters. You could change things like the length, the direction the hair was flowing (wind), etc. For the head, you could also make adjustments under parameter. For example, you could tweak expressions. Then for the body, I believe it was under shape, you could combine figures. For example, I could dial a bit of the Girl head onto a Victoria body.
Now I look for the dials under parameter or shape and the features are missing. Where can I find them?
By the way, I loaded Gen 2 and Gen 3 characters. Both seem to be missing the parameter or shape features I'm talking about.
Any help is much appreciated.
Thanks!
I found the answer. There's a tab called install. I guess DAZ DIM didn't install them. I had to install them from within DAZ Studio.
I was going to say it sounds like your Parameters tab was missing.
They were installed, theya re part of DS, but your layout wasn't shwoing them. They would have been in Window>Panes(Tabs).
