Transfer Utillity not working any more in 4.6
I've done this many times in 4.5 and upgraded to 4.6 and no more worky...
I have a teen character that I made a geograph for as I've always done in the past and when I use the TU, I set (Source = Genesis), (Shape = Current), (Target = "The Object to be Transferred") and under Show Options, a check mark in "Reverse source shape from target" The result looks as though it applied double the morph to the transferred object if I select fit to source. if I uncheck fit to source figure at the bottom of the TU, it transfers ok and looks as it should but as soon as I go to parameters tab and again fit to Genesis, it again ends up a little smaller and lower in the seen. I hope I just forgot to do something.
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Sounds as if the reverse step isn't working - if it lines up with the morphed figure when not fitted then it still has the morph embedded. Scale can be the real problem, if there's scaling applied try exporting a morphed bu unscaled Genesis and using that as a guide to adjust your GeoGraft to fit, then try running that through the TU.
  • edited December 1969
    Thanks for the response.
    It does seem to have something to do with scaling. The morphed only figure had the same problem so I tried it again with a stock Genesis figure and all worked fine. I'll have to go back and make sure I didn't inadvertently apply some kind of scaling.
