CR2 Export and V4
Paula SandersPaula Sanders Posts: 321
I am somewhat confused in how to do this. Here is what I want to do. I want to use the new fitting room in Poser 2014, but first I need to be able to open a figure there. I tried with exporting as an obj and it was a mess in the fitting room and in Poser the figure was black although on Render it showed the textures. I made a very heavy figure using morphs that came with Mage from Rendo and I want to fit V4 clothes to it. I'll work with the fitting room later and learn it better. I know I could create the figure in Poser, but I want to know how I can export a V4 figure from DAZ in CR2 format into Poser. Then I can decide what to do. I use DAZ Studio 4.5. I found the cr2 exporter and tried to follow the menu. I found I needed to weightthe figure before I could use the exporter but when I used general weights, it kept coming up with an error.
Thanks
    Thanks
    V4 is already in .cr2 format, you don't need to export it. Point Poser to the runtime folder, and V4.2.cr2 will be in Figures > DAZ People.
    If there's a morph you want to use, export as .obj and use that as a morph target for V4 in Poser.
  • Paula SandersPaula Sanders Posts: 321
    Basically, I created a new character with V4 as the base and many morphs from mage inj as well as expressions. Can I bring this new figure into Poser? OI can access V4 in Poser, but don't want to have to recreate the expressions and morphs once in Poser. I guess my basic question is: "Can the new figure become a CR2?"
    Try using the Poser Format Exporter to create a .pz2 file to apply to V4 in Poser. I don't know how the fitting room works for adding morphs to clothing.
    File Export cr2 on file format button.
  • zaintczaintc Posts: 282
    I want to export my genesis characters from daz to poser and then use poser fusion 2012 to merge into cinema 4d. I am unable to do this. i was trying to follow what was being said, sorry dont get it
