Bodysuits, Cloaks, Capes and the MFD with dForce
RCTSpanky
I really want a new bodysuit like the ones for M4 and V4, but with with tons of more material zones for the G8 and it should be ready for dForce for perfect fitting. And I would also like to see the medieval and hooded cloaks and some capes (for our superheroes) as dForce versions too. I don't know, if the Morphing Fantasy Dresses and their Add-Ons will work with dForce, but they are on my wishlist to for a perfect illusion of my "old" princesses.
I hope there is something in the pipeline by different artists.
Post edited by RCTSpanky on
MFD works just fine with dforce, haven't tested all the addons yet.
BTW, I was EXTREMELY peeved to discover recently that the G3M version of the Hooded Cloak would not take texture addons intended for the G2F Hooded Cloak (specifically the updated "world princess" textures).
Material zones can be added with the Geometry Editor.
However, one thing I have noticed with the Medieval Cloak for G2F is you have to remove the existing trim with the geometry editor or else it tries to go into "windblown" pose by itself. Fortunately, you can create a new "trim" line using the G.E., so no loss there.
As for bodysuits, dForce doesn't do "perfect fitting", it's more for "loosening up" (though I suppose if you reduced the Contraction/Expansion ratio on certan areas you could tighten things up - hafta try that).
