Genesis V4 UVS gap error
marco95marco95 Posts: 26
Hi,
As you can see in attachement picture, there is a little error on the bottom of leg if I put a skin V4 (ShareGC) on Genesis.
I have put the V4 UV.
The skin is shorter !
Do you know where is the problem and how solve it ?
Cordialy
Marc
324 x 379 - 33K
  • KatteyKattey Posts: 2,899
    edited May 2013
    If UVs of your Genesis are set to V4 and skin is made for V4, this is a texture problem, not Genesis.
    You can use this jeans texture as an overlay over skin through L.I.E. (although I don't know if it will work) or you can edit the texture in a image editor such as GIMP or Photoshop, making it just slightly longer. Or hide the gap with boots :)
    Post edited by Kattey on
  • fixmypcmikefixmypcmike Posts: 19,738
    Make sure all the material zones are set to V4 in case some of them got switched to something else. Does the texture work properly on V4?
  • marco95marco95 Posts: 26
    As you ca see in new picture attachement all is right with old V4 but not with genesis.
    As you can see ther is an other difference on the belt (hip).
    I have change the map in GIMP and all is ok, but I want to know why there is this diffrence. If there is a parameter to modifie it's more easy ;o)
    Marc
    800 x 640 - 77K
    Can you link to the ShareCG texture you're using? I'd like to run my own tests so that I can better find the solution to this problem.
    Are you getting this on all second skins? I haven't been able to duplicate it with any second skins that I have. Is your side-by-side a render or a viewport screencap? Were they done in one image or did you combine 2?
    Is there any bump or displacement on the second skin?
    edited May 2013
    Second Skin EdenEvergreen
    It's incredible it was the
    http://www.sharecg.com/pf/full_uploads.php?pf_user_name=edenevergreen&division_id=0&s=dd&pn=3
    >The EdenV4bodgloves_DAZ_seconde-skin
    But link are broken to day !
    No displacement, no bump and the view is the same at screen and after render....
    Thank's for your help.
    Marc
    200 x 200 - 11K
    Post edited by marco95 on
    Can you post a link to the item? There are a number them here: http://www.sharecg.com/edenevergreen
    Hi,
    I have make an essai.
    As you can see on the picture, V4 UV map (on right) are not the same on V4 and Genesis with V4 UV map (on left).
    Pershaps this little difference have no importance for usual mapping.
    Cordialy
    Marc
    800 x 640 - 393K
    Are you sure that's using V4 mapping on unmorphed figures? I'm not seeing that on any second skins I've tried.
    Ah, found the set you're using, and I'm seeing the same thing you are. Let me see if I can find a seam guide that shows where the leg and foot maps meet.
